My CTR has suddenly developed a nice new noise to worry me (to add to the existing noises...).
I can only describe it as a continuous chirp, a bit like a cricket. It seems to be located around the belts / pulleys, and doesn't vary with engine speed. It does vary in volume though, but again, not with engine noise - it's just random. It doesn't go away when the clutch is depressed, and doesn't change if the AC is switched on.
My guess is a bad pulley bearing, but I'm not sure which one; and I'm concerned it could be the alternator, or water pump.
Any thoughts? Advice on diagnosing the issue further?
