1 - 11 of 11 Posts
Last week my cigarette lighter stopped working. I found that fuse 29 was blown and so replaced it with a spare. A few days later it has blown again. Is there anything I can check myself before getting it booked in at a garage?
Thanks.
The Talented Mr. Robbieee
Yep sounds as if something in-line is definately blowing it. Or you may even have a short somewhere in the cabling. If you disconnect everything external you have plugged in, I would get it booked into the garage.
I am plugging in my TomTom sat nav charger and it works fine in other cars, so I guess it's a book it in job. Ah well! Thanks.
Small metal object stuck in the socket? A friend of mine had this problem with a punto, turns out there was half of a staple inside the socket that was causing a short circuit :rolleyes:
same general topic, but where is the fuse for the lighter located (fuse box under bonet or internally?) if internal where is the fuse box?
It's in your cars user manual if you have one. I am sure someone will post for you in here if you don't have that lol
figured it might be but as i was on here i thought someone might have the answer in their head to save me looking... (note to self stop being so lazy)
Above the Fuel and Bonnet openers - and a right **** to get at without being a contortionist.
1 - 11 of 11 Posts
