1 - 20 of 29 Posts
Hi, I was wondering if anyone could help me? I've had my car a couple of months and on Saturday out of the blue, the engine management light came on. The car is driving absolutely normal, nothing different to before. I have plugged in a Bluetooth OBD reader and it comes up with the code: P0069 - Manifold Absolute Pressure - Barometric Pressure Correlation.
Has anyone experienced this? I'm guessing the MAP sensor needs cleaning? I reset the code, however it comes back a day later. If it is something that can be sorted easily, where is it located?
Many thanks
Discussion Starter · #5 ·
Right clean your MAF sensor and check for vacuum leaks – Also regarding error code P2A01 you need to change your O2 sensor bank 1 sensor number 2 because it is giving an out-of-range performance.
Discussion Starter · #10 ·
I advised you to clean your MAF sensor NOT your new MAP sensor - The MAF sensor looks like the attached photo.
And yes change your air filter if it requires it.
1 - 20 of 29 Posts
