Hi guys,
I got a full ESM for the Civic 8. This is the guide given to dealerships to work on the Civic 8 and it basically explains in step-by-step details how to work on, repair, and replace each component on our beloved cars (1.4 i-vtec, 1.8 i-vtec, 2.2 i-ctdi).
If it's permissible by the admins I could post a link leading to it, so please let me know.
Tahnk you!
It's wery helpful.
How to Troubleshoot the Climate Control
How to Use the Self-diagnostic Function without the HDS
this shows no DTC errors of any kind
and this function works fine because when I disconected internal temperature sensor and run the test it indicated proper error code.
But next test
Displaying Sensor Inputs at the Climate Control Unit
seems not working properly at my car.
It is flashing only two numbers (16 and 1)
and switching beetween sensors using
No code has to be inserted here.
seems not doing anything ;/
But anyway youre manual is briliant!
Thanks so much!
Switch sensors with the knob for the rear heater
In the manual should be stated to use ac knob, but In my case the rear heater knob was the correct one.
