261 - 280 of 297 Posts
Its just a allan security but, fairly common everywhere and you can buy them readily.
Honestly speaking, I've searched everywhere I couldn't find it. The teeth is 5 not 6. Please if you can help me buy it. I will pay for it, I will for for freight and for helping me buying it.
Sent from my SM-G950F using Tapatalk
Please Bosses in the house, I found this article online but, i must be sincere is not clear enough.
What Repairs Will Fix P0780?
  • Change the transmission fluid and filter ( I guess the MTF 3 or Mobil Dot 4 they mean right?)
  • Replace faulty solenoid(s) ( I can't find any solenoid on Honda Civic Type S i-shift)
  • Repair or replace a faulty transmission pump ( I can't find transmission pump on Honda Civic Type S)
  • Repair or replace defective transmission valve body ( I can't find valve body on Honda Civic Type S)
  • Replace torque convertor lockup solenoid or clutch failure ( please enlighten me)
  • Replace output or input speed sensors (where on Honda Civic Type S do I find this)
  • Replace transmission range sensor (where on Honda Civic Type S do I find this)
  • Transmission flush to clean passages ( please enlighten me)
  • Repairing or replacing wiring ( please enlighten me)
  • Flashing or replacing ECU / TCM ( please enlighten me)
I will highly appreciate your quick and positive reply.
TCM is the Transmission Control module which is inside the iShift box itself. If the TCM (i.e. transmission computer) is faulty it'll throw this code.
More than likely the TCM is damaged.
While i appreciate you are in a bit of a bind here, what you're asking is for a professional to basically help you for free that he charges people to fix and rightly so.
You need to find a specialist in your area, or get in a working iShift box and link it with your HDS
Hello Bosses in the house,
I don't know if anyone is using OTC SPX MVCI. If you are using it. Does it reboot if you start the engine while it connected to the ODBII port? Please I don't know what I'm doing wrong. My OTC SPX rebooted while I was performing static learning.
The car is not starting again.
Please help my poor chap out.
I would greatly appreciate your quick and positive reply.
Thanks sir/ma
Hi. I have problem with Civic I shift gearbox, cog light on, won't turn over and stuck in a gear. Problem code P0909 (there were more faults but i was told this is the main one) Is this something you can fix? I'm in Guildford, Surrey. Thanks
Hi, I am based in Slough, Berkshire and my car has the same issue. Would you be able to look fix my car? Due to the distance, you may not want to travel this far, would you be able to advise if there a specialist local to me. best. Marrium
I have similar problems in my Civic semi-auto 1.8, 2007. Since yesterday suddenly my gear is not changing from N. I’m based on Maidstone, Kent, would anybody can help me to fix this problem. Specially any mobile mechanic who could help me to remove Gearbox actuator for repair/ rebuild. Thanks
