So, i had my car checked, and my front bearings are on their way out, i've found a replacement one on eurocarparts, but are they any good, are they worth buying?
Also my front right (drivers side) caliper is starting to seize. Are the rebuild kits too much hassle to do, or am i just better of buying a new caliper from eurocarparts, again, are they any good or should i go elswhere?
Also, does anyone know the size of the nut for the hub in the middle, is it 32mm or 36mm?
Thanks!
if there unbranded id leave them alone
some cheap and nasty parts from eurocar parts recently
and there not as cheap as they once were either
Go with OEM honda bearing. Rebuild kit could be purchased cheap from ebay, but if you never rebuild caliper - you won't enjoy it.
Check if there is any refurbished calipers for sale or contact specialist. Also if you intend to keep the car then do both fronts at the same time.
