I have 1999 Honda Civic with cvt transmission 1600cc, vtec. Most of the time it works ok, but after it's warmed up properly it misbehaves. When I stop at a junction etc. and then try to pull away, the engine revs rise very slowly and it takes a good second or 2 before the car starts moving. It's almost as if it's trying to pull away in a very high gear. As a result I have narrowly avoided a few collisions as I try to pull away and other drivers expect me to move more quickly than I do. Once I do get moving, the car behaves perfectly, until I stop at the next junction etc. The transmission oil has been completely drained, flushed and replaced with new Honda CVT fluid, and the car is generally in good order. The problem seems to have got worse since I had a new timing belt fitted - although that may just be my imagination. Also fuel consumption is very high since the belt change. Many thanks for reading this, and for any help you can give.
