1 - 20 of 78 Posts
Warning
I accept no responsibilities for these steps below, it worked for me, if it doesn't work for you don't come after me.
Here are some steps to replace the fuel filter on an 08 Civic Type R. These steps can also be used for replacing the fuel pump as the pump sits in the filter unit.
Before you begin, if possible do not start the car, or even turn the key as this will prime the fuel pump. If you leave it at least 24 hours before starting the job it will minimise the fuel spillage when removing the fuel lines.
It's unavoidable not to get fuel on your hands, and if your not careful your clothes as well.
So, do this in a well ventilated area away from flames. If you smoke be careful not to set fire to yourself when lighting up especially if you have fuel on your clothes.
Preparation
The fuel tank access cover is under the center console. To remove pop off the four plastic covers and remove the bolts. For some reason the bolts are imperial sizes (5/16).
When the four bolts are removed, lift up the front of the console carefully and disconnect the cigarette lighter.
Now you can lift the center console off and put in a safe place (your boot).
You will need the following part number 17048-SMG-E00
Remove Fuel Pump
Step 1
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Step 8
Step 9
Step 10
Step 11
Step 12
Remove Fuel Pump From Old And Fit To New
Step 13
Step 14
Step 15
Step 16
Step 17
Step 18
Step 19
Step 20
Step 21
Step 22
Step 23
Step 24
Step 25
Step 26
Step 27
Step 28
Step 29
Step 30
Step 31
Step 32
Step 33
Step 34
Step 35
Step 36
Step 37
Step 38
Step 39
Step 40
Step 41
Step 42
Step 43
Step 44
Step 45
Step 46
Putting New Filter Back Into Tank
Step 47
Step 48
Step 49
Step 50
Step 51
Step 52
Step 53
Step 54
It is a good idea to test the pump works before putting the access panel back on, make sure the fuel line is securely fitted and turn the ignition on.
You will be able to hear the fuel pump kick in, start the engine. If it starts then you can goto the next step and put everything back together.
If not, then go over the steps again and make sure you haven't missed anything.
You may need to prime the pump a couple of times before starting, turn the ignition on, wait for the pump to prime and repeat again. You may be able to hear some air in the system, this is normal and a result of removing the fuel line allowing air to enter the system.
Step 55
Step 56
Step 57
Step 58
Thanks for the positive comments.
It's supposed to be changed at the 80,000km service here in Aus. That would make it 50,000 miles in the UK but the service intervals may be different. But I didn't do it until 94,000km.
This was mainly due to various failed attempts getting any information from Honda Aus / Uk for the procedure. Finally I bit the bullet and did the job as I couldn't wait any longer due to the engine hesitating on cold mornings.
Good write up :)
I know very little about fuel systems and I have to say I'm quite surprised at the exposed electrical connections in that thing... What stops it going bang???
Thanks,
It's actually harder to ignite fuel than you might think. There is an upper and lower limit of air/fuel mixture for ignition. Anything greater or less than this limit will not ignite. These limits vary depending on the combustible gas but petrol is fairly safe.
So it's due to the fuel / air ratio inside the tank which means that liquid fuel will never explode. The electrical connectors do create sparks but because there isn't enough air inside the tank it cannot explode.
Great job and write up mate.
ohhh might excplain why it smells of petrol my car in mornings
Change fuel-filter
I know cars where you can do this job in about 5 minutes. This is so over the top. My Honda Legend V-6: on the bulk-head and one 10 mm bolt. Take off the fuel lines and change out the filter. Put new one on and start to check for leaks. Job done. But nice how to, very helpful, thanks.:D
Superb how to :D
Did you find you needed to clear any dust / debris once you removed the access panel before removing the filter assembly?
Also quick question, on the last few stages, why do you put the whole assembly into the tank before putting the large rubber seal around it?
Discussion Starter #14 (Edited)
@jamie_c69
thanks,
When I removed the access panel, there was a film of dust on the surface on the pump but once I removed the fuel lines there was a little fuel spillage and that made the surface nice and damp so there was a little chance of crap falling into the tank.
It might be an idea to wipe down the entire surface with a damp cloth to minimise the chances of getting dust in there. But to be honest, I live in a dusty / sandy climate and it wasn't so bad, so I'd be surprised if it's any worse for you in the UK.
Re the seal : No particular order, I put the pump back in then realised I had forgotten the seal... the seal is easily workable and can be put on over the top.
@Coordinator
I know right, a simple job turned into a right mess. The bad news is all the modern cars are going this way as well.
@ rawwu
I later found out the mysterious silver thing is the regulator...
@cv65user
Is your life insurance paid ? smelling fuel usually isn't a good sign.
@jamie_c69
Thanks, so i guess, might be easier to put the seal on first then drop the whole assembly into the tank
As I've already said this is a great How2 and I used it today to change my fuel filter (car has now done 63,000 miles) and it was great, only took a couple of hours taking it steady making sure I followed all the steps :D
Thanks again.
Any pics of your filter, was it dirtty
I didn't get any piccys mate, it looked just the same as in Stiggy's photos though. And the fuel pot had quite a bit of crap in there too.
I also struggled to understand where the actual filter part was as you can't really see it. It's just a load of plastic and you swap the pump and fuel pot over etc... and that's it :confused:
I don't know if it's just me but the car seems to be idling a bit smoother now so it might have been quite clogged.
Reactions: Type-R6
1 - 20 of 78 Posts
