Hi. Ive got some problems with a Civic ESi 92. It started with a loud clicking sound from the fuse box in the dashboard. Ive localized the sound coming from the Power Window Relay according to american diagrams of the inside relay- and fuse box in a Civic 92-93 EX and Del Sol. Everything seems to match with my box. Civic 88-91 diagrams shows that this relay is to ignition switch, but the other things are more different than my box.
At the same time the headlights stopped lighting (both low and high beam). The running lights in the rear(?) is lighting, and the parking light in front is lighting.
These two things got to have something to do with each other, because when I pull out the headlight relay fuse (nr. 16), the noise is gone. May this relay be a headlight relay? How can I find a electrical diagram of the dashboard fuse box of an Euopean Civic 92-95? Does anyone here got an ESi? Or have an explanation or advices?
Thank you!
Edit. ****.. 2006+ Civic Forum. Im not allowed to ask about a 14 year older car, or?
Thank you!
