^^ Like he says!I leave mine on auto all the time, so the ac is on constantly...
I think that's actually better for the car then offing and onning it?
thanks ron!When using Auto mode the air con is automatically turned on.
The only time you can be sure the air con is off is when you see A/C OFF on the display.
There is no benefit in having the air con on when heating the car, but there is when using the demist function(air con on by default), and it is recommended to use the air con for at least 15 mins on a weekly basis to prevent a build up of bacteria in the system.
You can leave it on peranently, it makes no difference in stopping and atarting the engine. The fans will turn off automatically when the ignition is turned off.thanks ron!
do you know of it is fine to leave it switched on before turning off the ignition?
and when turning on the engine will not make any harm to the a/c?You can leave it on peranently, it makes no difference in stopping and atarting the engine. The fans will turn off automatically when the ignition is turned off.
The only drawback is that when the engine is not upto running temperature the a/c cools the air before it passes through the heater matrix, therefore it takes longer for the engine to warm up. Consequently the air from the heater is cooler for longer.
It shouldn't do any harm as it is designed to work this way. It will increase the load on the starter motor particularly important if the battery is in poor condition.and when turning on the engine will not make any harm to the a/c?
btw Happy Christmas to all!!![]()
On models with climate control, the system turns the AC of automatically during warm up thus preventing the evaporator cooling the air.You can leave it on peranently, it makes no difference in stopping and atarting the engine. The fans will turn off automatically when the ignition is turned off.
