hi, i have an 07 es diesel model that it have a dual zone climate control & few weeks ago i made gas refill & poured a green liquid to check if there's any leakages. now the ac is not working good, when it is set to low temp from the passenger zone is blowing hot air & from the driver zone is blowing not so cold air, anyone encountered this problem please or any help what i have to check?:confused:
thanks in advance
Can you see any leaks on the AC pipes under the bonnet?
Or on the condensor/AC radiator up front? Do you see any dark patches on the matrix? Carefully check where the hoses joint the condensor.
If you've had a dye added, then a UV lamp/goggles should help you spot any leaks.
hi,thanks for your reply.to tell you the truth i didn't check it this week due work but i will have a look this wkend. so you think its not something related with the unit inside because i taught the its coming from the inside unit.
thank & regards
