1 - 18 of 18 Posts
The Clock Radio AC display is not showing anything and just blank, it was dim and showing little then goes all blank however the radio still works fine?
Is this a problem with the headunit or is it the LCD screen display problem? Is there a quick easy fix to this?
Are there any guides on how to remove and replace this?
The official word from Honda on this is that the head unit is faulty.
So the head unit needs replacing? Is the facia and headunit all the same for the 8th gen civic or is type R different?
The display works but just VERY VERY dim, would this be the backlight or would it be the connectors or power from the head unit?
Anybody have similar problem before?
Not sure if it is the display or the head unit to replace? Are all the head units the same for the 8th gen civic or is Type R different?
I think all the head units are the same. The displays are different though the type r is red on black and the standard is white on black.
JimJim
THis is a fault with the Civic and reported here many times and appears to be linked to the stereo unit in high temperatures. Mine does the same but only when the outside temp is over 18C but it reverts to normal when the temp cools. Not much use in summer and as lots seem to have this problem I assume it is a production fault that Honda don't want to acknowledge else they would have to repair. Hopefully the latest Civics won't have this problem. New display unit will be costly to replace and if it is the same model as taken out may not resolve the problem.
I fixed my radio clock display with no problem,At first i was only getting half of display the top segments was missing,I removed the display unit from dash opened up the unit and resoldered all the the joints on the top row of the ciruit board replaced unit and problem sortted now display is now fully working again had no problems since.
Was given to understand it would cost £400 to replace.
it cost me fifty pence for fine solder bit and half hour of my time.
How to remove Clock Radio Display,
1/ Take the small cover from top of the speedo by lifting up and pulling towards you.
2/ Now remove the speedo unit by pulling towards you been careful not to scratch or damage the dash.
3/ once removed disconnect the wiring plug.
4/ Now remove the top cover in front of the radio clock display by lifting it up,be carefull not to scrath this panel.
5\ Now you will see 2x screws at the bottom of the clock display,Remove them.
6\ now taking great care pull the radio clock unit towards you.Once out unplug the the wire from back.
(If you have a panel removal kit it will better for you to remove)
Now you have the clock unit out remove the cover from the back to reveal circuit board.re-solder the joints using a fine solder bit.
Before replacing the unit plug wire back in turn ignition on and all been well it should work. .....if all is well replace unit. (Good Luck) to all who read this with the problem. :D
I see this is a very old thread but I have the same problem. The display varies from fully working to looking like some sort of hieroglyphics or cling-on writing. I had the head unit replaced 5 weeks ago and it worked fine for a couple of weeks. At first pushing on the display fixed it temporarily, now that doesn't work either. So I take it from the thread that the head unit has a generic problem with poorly soldered joints, even a brand new developed the problem quickly.
I will attempt the re-soldering job. In the meantime can anyone that has done that report that it was a long standing fix and the problem did not come back ?
Hello! I experienced the exact same problem with the radio display. I followed the instructions given above by wordy on September 14th and problem solved! The procedure to remove the display is excellently described and it is quite easy. Pay attention to pull it out uniformly and straight so as not to damage it. After resoldering the pcb the problem is gone. .
I am having missing digits on the clock/radio display, giving the dash a firm whack brings back all the text, but this still annoys me. It seems worse in warm weather.
I swapped out my factory radio with an android one and thought the problem was fixed - only for the problem to return a few months later.
I'm thinking of trying this fix, how hard is it to re-solder the joints? I am a little clumsy and only have a cheap soldering iron. Is this something i should ask a more experienced friend with proper tools to do?
Bluepurple, I understand the problem you are facing is the problem no 2 described in xfiniti's 64 excellent post! This was my case also, I have not experienced the first problem, the repair of which seems a bit hard for me to do..
To answer your question the soldering is not hard but you need to be good at it as the contacts are close to one another (you can see in the picture xfiniti attached). It will solve the problem definitely, it has on mine so far..If you don't feel confident ask some specialist to resolder it, it only takes half an hour.Removing the display is easy just follow the steps and remember to pull the display straight out, not by angle.
Good luck!
Hi all, anyone tried this fix on a SatNav version display?
mine seems very dim and im looking for a fix...just wondered if this is it?
1 - 18 of 18 Posts
