41 - 60 of 60 Posts
So when you have a problem while driving can you look at rpm ? is car rev to let say 5000 or something and no drive ?
Wysłane z mojego SM-N910F przy użyciu Tapatalka
Discussion Starter #56
The revs do not go that high, the gear change feels a little slower and on a couple of occasions has taken a good few seconds before it actually accelerated after the chamge
Sent from my Nexus 6P using Tapatalk
Hi Gurus in the house,
I have similar problem.
Here is the code detected:
1. P19FC - Shift change actuator position learning NOT completed.
2. P0780 - Transmission shift change system malfunction.
The car start normally, but if I shift to drive it jerk and return from A to N on the dashboard while the gear lever still on drive.
I used Mobil Dot 4 fluid.
I would appreciate your positive reply.
Sent from my SM-G950F using Tapatalk
41 - 60 of 60 Posts
