Have any of you guys encountered an issue where your having to pump the clutch a few times when been stood for a while before it will select a gear? Also once your able to select a gear you only have to lift your foot a little and it accelerates, why has the travel of the clutch pedal changed?
Checked fluid and that's full.
Any ideas?
I have an 06 2.2 cdti civic
Happens when you have a blown rubber in the cylinders or when you have air. Basically not enough fluid is in the cylinders so they cant compress the pressure plate.
