1 - 13 of 13 Posts
I'm experiencing a clicking noise from my clutch pedal for a couple of weeks now. I can feel it in the pedal, and it feels like a broken spring or bushing. The click occurs when pressing the pedal for 1/4th to half before reaching the floor.
I've heard about the issue with the 8th gen Civic, but it does not seem common on the 9th gen?
Could it be a spring / part of the pedal box or should I worry about the master cylinder?
It's a 2012 Civic btw.
Here is the video.
Honda Civic clicking clutch pedal
Had the dealer check it. It was a spring indeed. They will look if they can get the part separately (spring). Though they ensured me that it does not hurt the car and is only annoying.
My Accord had an occasional clutch pedal click for 1000's of miles before I moved it on - never caused an issue ;)
Spring is most likely moving in the locating hole at each end as the pedal moves.
Perhaps a little grease will help to stop it?
I seem to have the same problem. Very annoying. Did you get the problem fixed?
Discussion Starter #7 (Edited)
I have gone back to the car dealer (generic car dealership) since I still have warranty left.
They said it was a spring or bus nothing serious in their opinion so they did not fix it since it involves replace the whole pedal assembly.
I have to say it's less obvious now since it is getting colder :)
I'd follow Wilmo's suggestion; Peer under the dash and locate the spring - Pop some multipurpose grease on there, pump the pedal a few times and I'm sure it will dissapear :) - I had a similar springy click from my accelerator that I cleared up just using a silicone grease spray.
I found some time (easy now with the partial lockdown) to get a good look under the dashboard. Like common advice on this forum I used WD 40 Specialist Lithium to grease up the spring and accompanied bushes. Works like a charm now. No more clicking or screeching when the temperature drops. How these small things can make me happy 🥳 Lithium spray FTW 👌🏻
Thanks for getting back with a solution :) I had a hunch that a tat of WD 40 could do the trick and indeed it seems to resolve it :)
It will for a while until it dries out.
Something a bit more viscous would stay longer
Just to be sure: it's not the regular WD40. That's a water detergent (hence WD ;)) and loses it lubrication in a hurry. You will need a lubricant, like the WD40 specialist series.
315410
Just as long as that does not affect the seals in the clutch/brake cylinders.
1 - 13 of 13 Posts
