1 - 2 of 2 Posts
I have now made a adapter for pressure bleeding the clutch. Holds pressure only low psi . Not used it yet has only recently changed the fluid. So give it some thought a came up with this. Has you can see from the photos
This is a plastic 1" inch pressure testing bung with a 10mm test point that I have screwed on a Male connection for my Sealey pressure bleeder. It fits inside the reservoir and turn the winged nut down to expand the rubber bellow for a tight seal. There enough room in the reservoir for this to fit. All done for under £10
Hood Automotive lighting Automotive exterior Automotive design Bumper
Jersey Sleeve Glove Automotive tire Tie
Musical instrument Guitar accessory String instrument Hood Motor vehicle
1 - 2 of 2 Posts
