Does anyone know how to code a new airbag module to the edu using an HDS ?
Last airbag module had an internal fault so had to buy a used one with no faults from ebay, but couldn't get the same model number so it has to be coded to the car.
Civinfo's Bulb Supplier
Have you checked the part is compatible and supersedes your old part no.?
Its from the exact same year and model as my car, but I've been told model numbers on the airbag module are coded to the ecu, so if you find one the same model number it should be plug and play. But its too hard to find one with the same model number.
