The obvious Dual Climate controls are both set Hi - yet drivers side and central vent are blowing cold ambient air, whilst the passenger side is giving out the expected heated air...
Is this a common problem or am I just lucky. ;-)
I did a quick search and this thread seems exact the same problem but there didn't seem to be any resolution..
http://www.civinfo.com/forum/bugs-faults-irritations/84706-driver-heater-vent-blowing-cold.html
Sent from my ONEPLUS A3003 using Tapatalk
Could be drivers motor bad mate. So it doesn't react on temperature change. You can easy see if it works or not when you change temperature.
Driver's side has no change to temp setting - it just blows in whatever the outside air is, which at the moment - even though mild for December - is not fun.
The passenger side seems to work fine.
Not sure how the rear is but am off for a drive today and will have sprog in rear seats so will hear how they get on...
Motors need to change position on tenperature change. Passangers only get air from front and under seats. No motor control for rear side, only front
Will have a fiddle with the heating controls when we are all on the road shortly.
You can see when your parked if motors is moving (by sound or looking at it). Divers motor is just on left above footrest.
By accident rather than design I have been off/away from the forum for a chunk of time.... didnt get this matter sorted and we are now into AC season - the air con works fine all round.
Will aim to explore this again before winter.
