1 - 2 of 2 Posts
Hi guys I have a 2006 cdti 2.2 that was throwin up random error lights and codes and now it wont let a computer re connect. Has anyone had or heard of this problem . Thank you 🙏
Hmm; Not sure what you mean? Are you unable to connect an OBD Scanner? Sounds like there may be an ECU Issue; A good place to start is by disconnecting the battery for 15 minutes - Furthermore, if the battery is getting on, consider replacing / charging it as gremlins are known to result from batteries that are going bad on civics.
1 - 2 of 2 Posts
