When i put the mobile phone (android) in the usb slot, the following message on i-mid "unsupported".My old phone htc wm was recognised.
I don't have a problem with AUX slot.
Can somebody help me with this?
Is it possible your old phone had lesser than 32 gb disk drive?
Flash drive etc must be no higher than 32 gb and formatted as fat32.
(max 700 folders and 65353 files)
Success
Greetings,
Dark Flemish
No it's because the newer Samsungs don't have a normal usb storage mode but instead MTP mode which mostly just works on windows/mac....
Better off with a USB stick
Are you sure about that? If this is the reason maybe there is an application or a trick with which the mobile can be regognized in the usb slot.
Yes I'm sure and I've been down that road with my previous car.
There's "supposedly" a app for a rooted android but it never worked for me so I wouldn't go down that path really.
Thanks for your help.I will continue to connect with AUX.
ο φλού
I managed to connect my Xperia to car system audio via usb.
I installed from play store an app called usb sharer.
