1 - 19 of 19 Posts
I installed my double din today and have a big problem. Not sure if it's something I've overlooked as I was losing day light when putting the car back together but my fascia doesn't clip in anywhere at the bottom. I can actually lift the whole unit up and there's loads of play in it :/ is there a clip or screw to fix the fascia from underneath like with the factory unit as now everything I go over a speed bump the stereo will probably try and jump out the dash as it's only secured by the 3 screws at the top and nothing on the bottom !!
There's must be something obvious I'm missing here. Surely it shouldn't be like this.
Any input would be great :)
I had to cut the dash on the lower left as I've seen in the how to's to get it to fit in. I'm wondering if I've maybe cut too much away :( is that the only fixing point on the bottom ? The bottom left ? Is there not one in the middle or on the right ? As my stereo isn't secured along the bottom at all :(
With mine I cut bottom left same as you and leaving the clip on new facia n/a but the middle and right lined up and clicked in I would call the supplier if nothing lines up :(
Well I've got the take it all out again as my reverse camera still hasn't arrived so I'm hoping I can rectify the problem then. Just doing a bit if research to give me a head start for next time :)
Where did you order the camera from? Its taken near to 2 weeks so far!! Unbelievably slow.
Any pics of the install so far?
Doh !! I feel a right tit. You know what I've done... I've not taken the clips off my old fascia and put them on the new one !! What a nob lol
Ordered my cameras from mr bozo. His shipment was late but it should've still been here by today. Hope it comes this week as I'd like to get it all done and dusted :)
Just taken some quick picks for u:
I cut a small hole in the centre pocket to route the USB cable through.
I mounted my dab aerial by the a pillar and earthed it to the a pillar (near side) and routed the mic for Bluetooth calling up the drivers side a pillar and mounted the mic on the sun visor :)
I would guess Hong Kong, it's not unusual to wait a month for stuff to arrive.
There should be three clips at the bottom, a horizontal one in the middle, a vertical one on the right, and another vertical one slightly to the left of the middle one.
Did you remember to move across the metal parts of the clips from the original fascia?
http://callcut.eu.org/uploads/ICE-Install/thumbnails/2013-10-26 14.16.24.jpg
Edit: just seen your new posts, as I thought, the clips weren't transferred :)
Haha no worries buddy glad you got it sorted mate ;)
Where did you put the USB lead on your install? Will the unit pick up album art from folders on the USB stick?
When connected via bluetooth, do you get album art by that method?
I cut a small hole in the back of the centre compartment whilst if was out of the car as I never use that pocket for anything so now all I do is plug in my USB/phone etc and put it in the centre pocket and close the old and it all looks nice and neat :) having a USB on the back of the HU was a must for me as I can stand wires poking out my dash anywhere lol
I've never had album art as I download songs off the net which don't come with album art. I'll download one on the App Store though with album are and see if it comes up on the screen and I'll let you know :)
A good free way would be to download mp3tag. Just navigate to your music directory, highlight your album, select tag source then click cover art then you simply need to tell it which album it is, nice and easy. Will write all the necessary info over to your files.
Hello mate. I forgot about this so I just downloaded a song with album art to my phone and plugged it in and it came up on the display.
Hope this helps :)
Discussion Starter #17
I didn't buy the leads mate no. That's just the phone plugged in via USB with a charger cable. When I plug my phone in to the USB it recognises it as an iPod on the HU so as well as charging It gives me access to all my music folders.
Discussion Starter #19
Yes mate you can search the USB for artist, song, album, genre. You can also search by alphabetical order. Basically you can navigate your way around the USB to find what you want lol
1 - 19 of 19 Posts
