1 - 9 of 9 Posts
Hello both cooling fans are running about every 15 seconds.
Even When the engine is cold?
I hear a loud klck When the fans turn on is this normal.
What ya at
Please help, the fans turn on and off , on and of every 10 a 15 seconds.
There was a couple of threads about this. There is a switch at the bottom of the radiator for water temp it suffers from rain water ingress which causes the fans to run constantly even when the engine is cold.
I had to change the coolant sensor in the radiator on mine as it was putting up a fault code, when it did it also made the fans run on when I switched the car off so may be the same fault. Gsf were doing the sensor for £22 and it worked a treat, think honda was around £70.
Tom
1 - 9 of 9 Posts
