Hi all,
I have a crank no start issue with my 62 1.8 v-itec. Car was running fine, pulled up to the house and it just died? Battery is very good, new fuel pump and good pressure, checked the coils/plugs and they're sparking as god intended. Checked for broken cam chain and that's all good plus rpm on gauge when cranking? No warning lights or codes with professional scanner? Local garages won't touch the car and even my local tuning/diagnostics specialists says "nope, as there is no money in spending hours trouble shooting." I am going to have a go at pulse testing the injectors as I feel they might not be firing?
Does anyone have any ideas?
Where is the PGM-FI main relay on 9G, easy enough to find on 8G? How do you remove the injector fuse no 6 in engine fuse box, have never come across this design before and don't want to knacker it or the box... thought I might swap it with the A/C fuse to test. I could really do with some help as next step might be to scrap the car.... 10 months MOT, 113k and full Honda S/H plus £2000 spent last year on new cat/clutch/brakes/tyres!
