Mode Photography
has anyone else had a problem with there door handles coming loose????
My civic has been back to the dealer 4 times now due to door handles coming away from the door, gatwick Honda has replaced one side and tightened the other but problem keeps coming back.
My warranty runs out in couple of weeks so worried what will happen next time they start to fall off,,,,,,,,,,
more torque than the mrs
very common problem if you check on this forum had my passenger side replaced about 6 weeks ago it became that loose i was unable to open the door from the outside and the inside lucky for me it opened on the day the new part was being fitted,have noticed a little bit of play in the drivers side will be keeping an eye on it,if i was you i would demand a replacement on the one they keep tightening as its clear it will become loose again,good luck.
Not had them come loose but the wife can't get into the passengers side as it's too stiff to operate (arthritis doesn't help).
Can't understand why they should keep working loose though? Mechanics got limp wrists or something :)
