1 - 17 of 17 Posts
Cruise Control Civic Si, is it possible???
Hey guys
I have a 60 plate Civic Si 2.2i-CDTi.... it doesn't come with cruise control as standard and when I asked at the showroom they said cruise control couldn't be fitted to this model as the wiring loom was different... Im not entirely sure I believe that so if anyone knows if its possible to do, that would be great
Thanks!:D
Discussion Starter #2
Nevermind guys just found out if cruise doesnt come as standard its not something honda can fit
Yeah they r right.
An es or ex would have cruise
OMG8THGENEX
I'm lead to believe that you only need to swap steering wheels with that of an EX which has the cruise control buttons as the wiring is already there.
parts you will need:
  • steering wheel with cruise control.
  • steering boss unit from a ex gt model, or any model that has cruise control.
how to:
disconect the battery and leave car alone for 15 min
remove airbag and steering wheel
remove plastic covers around the indicator/ wiper stalks
undo unplugs then remove indicator/ wiper boss unit.
insert replacement, reassemble.
the car has a active ecu, so it automatically detects new hardware and updates itself.
£890 !!!!! Phew
Will be more careful with mine in future.
when i took my car in for a service, they changed my cruise control mechanism becaus of a common fault and as far as i know, it some how saved the throttle position at the time of the set, so does this mean the throttle position is recorded by the ecu, so that the cruise control can access this though it?
If its anything like a BMW, as well as fitting the wheel itself, the dealer would also have update the relevant ECU to accept the different spec bits.
thats what i thought, and then thats when things start getting very expensive.
most cars use bosch ECUs now so id say its very much like the BMW
The ECU update might not be too bad. I think they'd probably just charge labour. It is not a hardware change, just a soft/firmware settings adjustment.
At those prices I'd just try and keep my right foot still instead :)
I rarely use mine. Just as you get it set you catch a lorry just as a convoy of cars comes past so you have to cancel it.
I think I used it once at about 04:00 in the morning up the M40
Doesnt look like ill be getting cruise with prices like that! haha
Cheers anyway
[QUOTE = "Andy_K, post: 1055972, deksel: 7288"]
Ik ben ervan overtuigd dat je alleen de stuurwielen nodig hebt om te verwisselen met die van een EX die de cruise control-knoppen heeft, omdat de bedrading er al is.
onderdelen die je nodig hebt:
  • stuur met cruise control.
  • stuurkopeenheid van een ex gt-model van een ander model met cruisecontrol.
schoffel:
koppel de accu los en laat de auto 15 minuten met rust
verwijder de airbag en het stuur
verwijder plastic afdekkingen rond de indicator / wisserstengels
maak de stekkers los en verwijder de indicator / wisser naafeenheid.
plaats vervanging, monteer opnieuw.
de auto heeft een actieve ecu, dus hij detecteert automatisch nieuwe hardware en werkt zelf bij.
[/ CITAAT]
[QUOTE = "Andy_K, post: 1055972, lid: 7288"]
Ik ben ervan overtuigd dat je alleen de stuurwielen hoeft te verwisselen met die van een EX die de cruise control-knoppen heeft, omdat de bedrading er al is.
  • stuurkopeenheid van een ex gt-model of een ander model met cruisecontrol.
hoe:
de auto heeft een actieve ecu, dus hij detecteert automatisch nieuwe hardware en werkt zichzelf bij.
[/CITAAT]
hallo, ik vraag me af van het eenvoudig is om cruise control te bouwen, wat niet standaard is. Ik heb stuurinrichting met cruise control gekocht. het blijkt dat de klokveer geen 18 pinnen heeft. eigenlijk ben ik op zoek naar een klokveer met 18 pinnen. maar ik las dat ook achter het sturen van knipperlichten etc. vervangen moet worden? en pedaalschakelaar niet aanwezig. moet dat ook worden opgenomen? er is geen kabel .. Ik hoop dat je me **** helpen met tips.
ik heb Honda Civic 3dr hatchback type S 2007.
1 - 17 of 17 Posts
