1 - 9 of 9 Posts
Hi Everyone
So I had an issue with my cruise control where it would work intermittently then just packed up entirely, I found the fault to be caused but one of the clutch switches which I tested on a multimeter.
I have replaced the clutch switch and works evertime now without fail, also I did have issues with the squeaky clutch which normally i would douse with lube but since changing the switch seems to have disappeared so would assume that it was linked.
I have made a quick YouTube video showing the faulty part in question.
Clutch pedal guru
You can normally spray contact cleaner inside the switch down the side of the plunger. A load of black crap will come out and it'll normally start working again.
Hondacivicnut I did try cleaning it up everywhere possible with electrical cleaner and just wouldn't have it unfortunately.
Did u push the plunger down and spray inside that with electrical cleaner. Hondacivicnut told me three times till I realised what he meant and when I did do it, it fixed the problem entirely :)
Hi there, sorry for reviving an old thread. Where did you get the switch and for how much (if not from Honda). Thanks mate!
think I have issue with my clutch switch
when on cruise control it don't knock off when using clutch it does when you touch the brake pedal though
mine is a 9g mind
Moderator
I'm fairly certain that changing gear, thus using the clutch, does not switch off ACC on my 10G. That's without going out to double check, but I will later and report back.
Touching the brake pedal certainly does.
did wonder if it was a feature
any other in the past even my old accord knocked off with the clutch as well
1 - 9 of 9 Posts
