1 - 2 of 2 Posts
Cruise has stared to cut out on its own recently, all electric controls seem to be working Ok so I would suspect its one of the mechanical switches on the clutch pedal. So is this the likely cause and I've had a look at the pedal and there are two switches. Which is the one for the cruise control? What could other causes be? Thanks Ed
Discussion Starter · #2 ·
Think I might have found an answer to my question, had a good look through the threads and found the picture so I can see which switch is for the CC. (Interested to know what the other one is for though) Also had a closer look at this and the activating rod seems very loose when the clutch pedal is pushed down, almost like it's going to fall out which doesn't seem right. Will get a new one and see if that cures it.:)
1 - 2 of 2 Posts
