Hi Folks
I installed a Double din pioneer avh-3100dab last year, it came with a DAB aerial in the box. Its the small black pencil type that sticks to a window, it has no ground metal tab that people talk about and at the other end just the small pop connector straight to the head unit.
I have two issues DAB and FM reception
To be honest I never really listen to the radio and reception when tested in my driveway was ok. Over the past few months, iv started to listen to absolute classic rock and noticed how unreliable the signal is even on all the channels, I checked the connection and its ok and tried various locations on the windscreen to improve reception but its crap lol.
Without putting an external DAB aerial in, can anyone recommend the best option.
Also the FM aerial on these cars wasn't great anyway, but with the new headunit fitted and all connections in place its even worse, has anyone found this after making the switch to double din on FM radio
Thank you
Hi, I've used the autoleadd DAB film antenna from Halfords.
I fitted under the side cover, away from the airbag, was fiddly but made the earth connection and live in rural Cumbria, reception is as good as our C4 picasso.
Did you use the correct adapter for your radio aerial? Needs to be powered,.connect2 have one, I have better reception than I had before I think.
Mite try this type of DAB aerial, mine doesn't have a ground/earth you see and mite be a cheap nasty one.
Yes I bought all the connect2 leads, I plugged in the adapter and connected the FM aerial and power connection. Had a look through the forum there, maybe its to do with the ground for the aerial around the boot location being bad
Ah luckily my boot ground seems ok.
I found a post where someone had lifted the side cover gently just below the airbag, using several hands and screwdrivers I managed to get my earth strip onto metal and cable pulled through so I could hide it all.
Its tight and a challenge I'll be honest
