1 - 2 of 2 Posts
Hi All.
Loads of good guides for New ICE fitting but I can't seem to find anything for how to route a wire to a DAB Screen aerial or different option please?
I wasn't sure on this either, so I stuck mine to the rear passenger window (3-door), routed the cable down past the speaker, under the door and up to the head unit underneath the glove box, which was pretty straight forward. All you need to do is remove the side panel to access the back speaker (loads of guides for this) and lift the side panel slightly to get the wires down and stick the earth tape thing to the metal work. All the panels just pop out/pop back in.
Alternatively, there are adapters on amazon which use the FM aerial of the car to get a DAB signal - can't comment on how good these are though, but will be a lot easier to install.
https://www.amazon.co.uk/Eightwood-...id=1508596851&sr=8-2&keywords=dab+fm+splitter
1 - 2 of 2 Posts
