1 - 9 of 9 Posts
MY keyfob has had better days,
I've seen replacement keys on auction sites. I was thinking of swapping over the pcb into the replacement keyfob but want to avoid get a blade cut. Does anyone know if the blade is removable on the keys?
Thanks,
#MrGrumpy
Thanks,
The PCB and buttons are a separate unit to the blade, and can be easily removed and replaced.
The member Wardy2602 is soon to start up his long standing 'Key flipping service'.
http://www.civinfo.com/forum/civinfo-traders/110596-flip-key-conversions.html
The cost then was £35 for the work, a new key with key blade and return.
Worth looking at if you wanted to update your key ;)
Edit- I believe the blade is molded in the key so most likely a pain in the bottom to remove and reattach the blade in a new case
Reactions: wardy2602
SHOCKD
#MrGrumpy
Sorry, I totally misread the opening post and thought this was about transitioning to an already cut key :facepalm2:
If I remember correctly it's possible to remove the blade also.
No Smoke no poke
Thanks,
Hi buddy
Unfortunately the blade is molded to the case, the only way round that is to either replace the key with an oem one (Just the shell) but you will need to get the blade cut, or as others have mentioned Im just waiting on stock and will be back up and running again but provided a flipkey service i provide a new flip shell, modify your remote to fit and get it cut.
If you need any help just drop us a pm mate.
Cheers for the plug fella - Back soon ;)
+1 excellent service!
Shame someone came along and ruined it though.. Hopefully when hes 100% he can start that thread up :D
Cheers fella, all good going no where and will be back as soon as new stock arrives ;)
SHOCKD
Hi buddy
Not a problem at all matey! Always give credit where credit is due etc ;)
Thanks all.
for now I've ordered a cheap case for about £2.50.
Will see how it goes as a temporary measure anyway. I'll definitely consider the flip key conversion one Wardy2602 has them in stock.
1 - 9 of 9 Posts
