Hello!
My windscreen mists up almost every time I start the car. I had originally thought maybe the pollen filter was clogged and restricting air flow, so I popped it out to check and it was damp.
I searched and found this post:
In the place where the filter is is a little hole on the bottem You have to blow it clean with air The little hose is probebly full with dirt and thats why the water is not going out of the bottem of the car. Its a quick fix
this is the hose under the car
So I'll check this now, but can anyone else think of any other reason my pollen filter would be wet?
Cheers!
you gotta remember our climate is not the driest
the pollen filter draws the damp air in from out side and filters it
wont take much in this country to get some moisture in there
what setting do you have the blower on if you have it on recycle rather than fresh air from outside that could be your problem
