1 - 15 of 15 Posts
I Hate tailgaters!
Just bought Nextbase 312GW. On offer £84 at Halfords (until 5 June). Installed in car in 10 minutes. Seems OK to me on video quality but as I've never had one I've nothing to compare against. It has wifi and I've already paired with phone (iPhone 6) and downloaded a 5 minute clip (467mb).
Question is this, as I've not had it hard wired in yet. I'm using cig lighter socket. It recommends disconnecting when not in use but it is quite a job to get it out so how many of you just leave it in ?? Or do you yank it out when not in use ( no double entendres intended ) I'm worried it may cause unnecessary wear and tear to cig socket, or it falls apart.
Plus do you leave cam in place when car parked up or take it with you?
Sent whilst plotting to take over the world.
Ive hardwired my Nextbase 402G into my car, so I cant remove the wiring (its all hidden behind trim anyway) but the camera itself, I take it out of my car, I see it as the same as leaving a SatNav or phone in the car, its just an opportunity for some scrote to break in a nab it to make a few ££. If Im not at home, I hide it away in one of the storage boxes in the car.
On a Sidenote, The Nextbase DashCam hardwire kits are really good, just a few modifications needed to get it to fit the options pins. Maplins sell the HardWire kits for £14.99, £5 cheaper than Halfords. However, if you buy a NextBase cam from Maplins, you get the hardwire kit for free...I missed out on that deal also :(
Reactions: Red Dwarf
I Hate tailgaters!
I take it you hardwired yourself? How difficult was it. I'm no electrician so considering paying £30 to Halfords. And what modifications where needed. I know civic has smaller fuses. Am I correct in thinking 1 connector goes into power socket in fuse box and the other goes to a earthing point.
With the Nextbase hardwire kit, you literally remove a fuse, pop the piggyback connector in the kit into that now empty socket and then place the fuse you removed into the piggyback.
The nut that holds the fuse panel in place can be used as an earth point.
Oh, and for the record I leave mine in the car, if you can position it correctly it's actually hard to see from outside. My neighbour has even coloured the logos in with a black marker to make it truly "stealthy".
Just make sure to choose a fuse that is off when ignition is off!
Its easy, I dont do electrics at all, its really basic stuff.
The fuses that come with the hardwire kit are too big for the civic(at east for the 9G), so you cant piggyback the fuses.
Get the hardwire kit.
Get an Options plug + pins from x5252x on here.
http://www.civinfo.com/forum/civinfo-hobbyist-traders/230602-%5Bcoming-home-lights-drl-module%5D-%5Boriginal-option-connectors%5D.html
When it arrives, cut the bullet connector off the end of Live (red) wire, crimp on a pin that comes with the options connector (as supplied by x5252x)
Push the pin into the correct location on the blue plug. **Note this is the 9G Pinout, the 8G Pinout is different** There are 8G Pinout diagrams on here, but I dont have it readily available.
Then you will need to remove some trim, to be able to earth it, with the black wire.
(Skip to the bit where the trim removal pics are)
http://www.civinfo.com/forum/how/109014-%5Bhow-%5Dhardwiring-dashcam.html
Earth it to the screw as shown in Grayfox's How To guide.
Route the cables as you wish.
Plug the blue options plug, into the options 'socket' on your fuse box.
Job done.
If you dont want to use a options plug, you can use female microspade connectors, however, i suggest using an options plug, as its a lot more sturdy.
Thats pretty much it for a nexbase, but i got all this from various other 'How Tos' on this forum. Read both guides and look at the pics in both, to get the idea. However, Grayfox's guide is a from scratch hardwire, not with a kit, like NexBase supply.
http://www.civinfo.com/forum/how/64072-how-use-tap-into-fuse-box-option-connector.html
I've hard wired my nextbase too, using the option connector
I found a little black electrical tape over the silver writing helps to disguise/camouflage it
Mine is hidden behind the rear view mirror and is a little awkward to get in and out so I leave it in situ
The optoon connector is a really neat solution.
If you leave a dashcam in your car on a hot sunny day, doesn't it risk damaging it?
I wouldn't want to be left inside when/if the sun is shining!
MY13 9G Civic Auto
Good point if the windscreen is in full sunlight. I remove mine if I'm leaving the car unattended for any length of time.
A bit easier since I removed the Nextbase locking tab.
From what I can gather, if your dashcam has a battery, high temperatures for prolonged periods of time will damage it.
But if your dashcam uses a capacitor as its backup power source, theres no worry of it degrading in high temperature, or risk of it overheating.
But its better to be safe than sorry, I take mine out, or hide it in my car if im away from home.
I wanted a dash cam that I could leave in situ so I fitted a one that uses a capacitor instead of batteries- much safer and less troublesome in the longer term. It's flat mounting plate adheres directly to the screen and the small camera slots directly to that- without the traditional bulky suction mount. It therefore discreet and looks more like an OE lane departure unit than a camera. Photo makes it look more noticeable than it really is. I chose this mounting position as the lens is just inside the wiper sweep.
Reactions: Farqui
Capacitors have a temperature rating and can easily fail when you exceed it.
Now it wont matter in the UK since it doesn't really get that hot there.
Spot on Grayfox- even less chance of it overheating in Wales:laugh2:
1 - 15 of 15 Posts
