1 - 20 of 27 Posts
right after having a straight through exhaust custom made from cat back , i have been looking at removing the cat as well
but after a little search on here i cam across a thread were fahad mentioned not to remove the cat as this could cause issues with the turbo
how many 2.2 owners are running a decat on here, if there are have you had any issues
or can anyone else advise on this
phil
Hello mate, as per reply to your PM, in my own opinion it's a bad idea as the turbo relies on backpressure to help it run efficiently. By derestricting, you are making it work harder.
Not on a Civic, but I've seen firsthand on a 58 reg 90k mile Seat Leon 2.0 TDI.. car was decatted, had been for a few weeks.. turbo started sounding a little weak.. car tuned, and within 20 yards on test drive - BOOM.
I'd only read about decatting being a bad idea on diesels before then.
Discussion Starter · #9 ·
ok cheers guys , just remove the bottom one then
chip: dont surpose you could help me out if you still have your cat, i need a template of each flange so i can get the flanges made, so i can get mine decatted in one visit to the exhaust shop
thanks
phil
old flange pillagers... am I the only one who thought that sounded quite funny? :D
Civinfo Wind Up Merchant
I wouldn't remove the first one, as F6HAD said, the turbo needs some resistance (in the form of backpressure)
This was why i was worried about the Martelius, but it made no boost difference :)
The second one is more of and 'extra' and shouldn't make any difference if removed, just a better flow of exhaust gasses
Discussion Starter · #16 ·
Massive thanks for the flange diagram.
Did you find it on the net or source yourself.
Problem is I need the same for the flange on the other end of the cat as well
Thanks again
Phil
Cockup Specialist
Thanks again
Phil
I measured it and cad'd it ;)
You'll have to wait fo rthe other one
:bootyshake: [smilie=cheeky-grin:... studying
Discussion Starter · #18 ·
thats fine i dont mind waiting
i think the bottom flange on the cat has studs in??
if it does will it matter if i dont put studs in and just use nuts and bolts to attach it to the rest of the exhaust system
massive thanks again for you help
phil
Cockup Specialist
Both ends have studs ;)
Bolts replacement available on lings honda I believe.
Look like M10 thread..holes are 11mm on the flane I measured.
Discussion Starter · #20 ·
ok thanks i have only seen the bottom flange ..lol
will see what i can soucre regarding the studs , but if there is a problem will standard nut and bolts do the job , as long as the bolts are tight in the holes???
1 - 20 of 27 Posts
