1 - 20 of 20 Posts
I've picked up a nasty scratch just behind the front passenger's door. It is quite deep, and around 4-5 cms in length.
There is a also a small bullet sized dent and scratch below the door handle.
Went to a couple of body shops, and asked Chipsaway and they reckon there is no other option but to paint/lacquer the entire panels which is going to end up costing £250!
Since the scratches are quite small I don't want to go with this option 'for now'. I'm sure they were caused by the neighbour's annoying kid on his bicycle, so not gonna bother repainting until I move to another place.
As a temporary solution, is it okay to use something like a Honda touch up paint or Dr.Color Chip?
What's the best (read:cheapest) option to disguise these temporarily?
Sold a kidney last week!
Sorry to hear about this mate - personally, I would leave it and wait until I could afford to have the issue rectified properly. It's not about making the situation worse by fiddling with it.
T-Cut won't work, if the scartch is deep - and I seriously wouldn't mess about with touch up for anything more than stonechips.. So I'd seriously wait.
Why couldn't you use the touch-up for now? If he's gonna respray it anyway in the future?
Although thinking about it, I guess it could look worse than just a faint scratch maybe?
Discussion Starter · #4 ·
Thanks for the response mate. It sure is annoying when you put in so much effort in waxing and looking after it.
Your suggestion makes sense, I'd rather wait until I can get it done properly.
The only thing that's stopping me is I just dont trust that bloody kid! I'd have a word with the parents but I have nothing to prove that it was done by him.
Discussion Starter · #5 ·
Yeah, that's what I was thinking....that a faint red line would be much better than the in-your-face white line.
Red felt tip pen will mask it a little
I would get a quote from a bodyshop for the dent and a repray of the door.
Its the only REAL solution
Discussion Starter · #7 ·
I also considered whacking the Type S sticker to cover it up, but it would only have to be removed while respraying.
Get the dent pulled , then DrColorchip
Foglight Covers FORSALE
if you pay and get it sprayed it will never be as good as a factory job. touch it in the best you can just to stop it going rusty, then put a type s sticker over it, it will look better and save loads in a respray.
Discussion Starter · #11 ·
what product would you recommend for the touch up?
Try using a touch up kit from Halfords. (About £10.99. )
It's a 3 pen kit, with very fine knibs.
You need only use the colour pen.
After touching up, wipe over the area in the direction of scratch with white spirit on a soft cloth, to bring the new paint down level.;)
As JTL says halfords pen let dry for 5 - 10 mins use an abbrasive polish and cutting pad to remove the excess repeat procedure till the paint is the same level or go the whole hog put a thick layer on and wet sand 2000 grit and polish out till flush.
Had to do this a few times and the results were great virtually invisible on my bonnet.
Any respray has got to be better than a Honda Factory Job, surely nobody paints that bad ?
That's not true
Ive had the whole rear of the car resprayed.
It now IS better than before!!
That's not true. I've had the whole rear of the car resprayed. It now IS better than before !!
Ditto - I had the bonnet and front bumper resprayed - the paint now has a thickness measurable in more than nanometres ! ...
Discussion Starter · #18 ·
I think respraying is going to be inevitable (as it was suggested by 3 different body shops) but I'm keeping it on hold just for now.
Touch-up will only be a temporary solution.
Will BHAB + AGHDW on the scratch prevent any corrosion?
Yes..BHAB has rust inhibitors in the mix
The one thing that disappoints me more than anything about my Type S in black is the quality of the original paintwork.
After 38K the front is covered in white chip marks. The paint seems to be very soft compared to my mate's BMW with 89K on the clock and almost no stone chips!
1 - 20 of 20 Posts
