Having had a Civic Type S gt 2.2 cdti for 2½ years now with no idea how old the pads were, I got a free brake test done and everything is fine, plenty wear on pads, I am very light on the brakes !
opcorn:
It made me just check the web to see diesel driving styles v petrol, think I pretty much worked it all out myself, this Civic being my first diesel. However, I judge junctions well and slow down by gears, so these conflicting answers interested me as they are almost totally opposite, which is correct then ha ha :worms:
10+1 Tips to Driving a Diesel Car Economically - The Green Optimistic
9)THE GREEN OPTIMISTIC SITE SAYS :- Do not use your engine brake to stop. Coast to a stop either in neutral or by holding the clutch down. Using engine brake (gearing down) wastes a lot of fuel. It’s true that this is a harder job for your brake pads, the difference is insignificant, and your clutch will not wear out as quickly. Brakes cost less than clutches do, and when combined with the gas you are saving, it’s a far better choice.
How to Drive a Turbo Diesel Car with Manual Transmission Efficiently
14)WIKIHOW SAYS :- Engine braking (gear down) to slow or stop, in modern diesel engines uses less fuel than just braking, or coasting to a stop either in neutral or by holding the clutch down. This is because modern diesels have direct injection which is computer controlled. At idle, the injectors are delivering a very small amount if fuel. When you use the engine to slow the vehicle at speed (throttle closed), the injectors shut off. While the engine braking (gearing down) method of stopping is easier on your brakes, it is harder on the clutch. Brakes cost less than clutches do, so it depends on the situation for what the better choice is.
Confusing ?
Confusing ?
