I was told it is very awkward 'AND' necessary to remove battery to do this Bulb change.
Any advice welcome - is there a 'HOW TO'??
I'm sure I've seen the instructions in the manual.
I think I'd pop mine into a dealer as they have the experience and the know how to do it with less dismantling.
Fortunately I've not suffered any blown bulbs for a very long time (1970's Hillman Hunter main headlight) so hopefully ..................
Rob
I upgraded my side and headlight bulbs when i got my car in October . If i recall on the O/S take a clip out that holds the water bottle neck and it just pops out and you can get in quite easly then refit the bottle neck. The N/S is a bit harder I am sure i took of the intake pipe next to the battery same type of clip as on O/S . This let me get in JUST it is a tight squeeze but if you are carefull and take your time should be ok . (only attempt if you have small hands) .
Rob
Many thanks for info, unfortunately 'DON'T' have small hands - could be in trouble!!!
