Hi, I was wondering if anyone knew how to manually adjust the dipped beams on the 9th gen Civic?
My headlights are aiming too low even with the electronic dipped beam adjuster set to 0.
There are markings on the chassis above the headlamps that indicate they CAN be adjusted but I can't find the screw anywhere!
Lots of info on this for the North American 9th gen and European 8th gen but couldn't find it for the European 9th gen.
If they are the same as the 8G then there are two large white plastic adjusters which take a hex key, these should be right next to those marking for L-R & U-D
Discussion Starter · #3 ·
Good call - I saw those and falsely assumed they were mounting screws. Thanks Wilmo!
