1 - 12 of 12 Posts
hi there.
ive bought a civic 09 from salvage and ive fix everything and it work fine.the speedometer was faulty so i replace it with a second hand one and it work,my only problem is the milage on it is 22000 mile and my car has done only 2000 mile,how do i get it reset and how much is a new one.or do anyone know were i can buy 1 with a lower milage.*****
The White Knight
You would need to buy a lower milage one and get it clocked up i don't see a dealer clocking it back illegally someone might if its possible with Civic Mileometer
You need to either get a new one from Honda or a used one with less than 2000 miles on it to get it clocked up
i am not too sure as i have not ever tryd to do this but there is a possibility it can be done using hondas diagnostic computer. best thing to do is ask your local honda dealer and see if they will sort it out for you.
thanks guys,ive talk to honda and they say there nothing that can be done and they say i need to buy a new 1 that cost £300,i was thinking of getting 1 imported from japan but i dont know **** who can do it.
Would think Honda must be able to set this for you, they will need to do that if you buy a new one. Is it a question of legality ?.
well, ive contact them to reset it and according to them it cant be change. i thought that they could synchronise it to my car s computer or somthing but they say there nothing they can do.if any one knows where i can it reset that would be nice.
Jaguar Master Tech
Not too sure if the Honda system is the same, but to give you an idea of what may be required, I'll tell you about the PSA (Peugeot/Citroen) odometer (mileage) storage system:
The vehicle mileage is stored in the Engine ECU, Speedometer Assembly, and the BSI (Built-in Systems Interface, the main body computer). When ever one of these components is replaced, the one with the highest mileage becomes the default for the other two components, i.e. if a set of clocks (speedo) from a 50,000 mile vehicle is fitted to a 20,000 mile vehicle, all three components will now read 50,000 miles. The only way to reset the mileage is to replace all three components at the same time, the idea being that it makes it hideously expensive to clock the mileage.
Reactions: afro
The normal way to do this (but it's to late for you) is the following:
- you go to a dealer with your car and the old dashboard still mounted
- the Honda diagnostic tool reads the odometer for your car and stores it
- you/dealer mount the new dashboard and the stored data is transferred to the new/secondhand dashboard in your car from the HDS
The dealer is right: at this moment they can do nothing anymore.
sorted
***** guys. ive got it sorted. ive manage to get my speedometer to its originale millage,ive found a garrage that does milleage correction.
***** for the help. merry xmas to u all
sorted
thank u guys.ive took my car to a garrage and they corect my millage,was a bit expensive but at least the millage is now correct.im so happy..thanks for your helps. have a merry christmas
Hi there, I have a similar problem and I need to replace my speedo/rev counter unit. Can you confirm that I can buy a second hand one and fit it. Will it need coded to the car or will it be plug and go. I can lay my hands on one that is reading only 118 miles more than my car.
1 - 12 of 12 Posts
