Have just got the Do-Luck braided line kit, first question is that there are 3 blocks, I was expecting 4 so am hoping someone can shed some light on this? Also, have got Motul brake fluid, however, the brake fluid reservoir is close up against the bulkhead so does anyone have any tips about bleeding - I was hoping to use a pressure bleeding kit or do I have to resort to the old fashioned pedal pumping method?
Any help much appreciated.
The drivers side rear dosen't use a distribution block. The passenger side rear block is a bit of a PITA to get to as well.
When your changing them, unbolt the brackets from the chassis (2x10mm heads) and undo the bolt on the back, you might need a vice. Also unblot the pipe thats bolted to the bracket on the passenger side rear. Not too difficult to do but yes you'll need a bleeder and a mate to give you a hand :)
