Many people now use Snow Foam as part of their wash regime
BUT what is your technique in its application?
I used to apply on a dry car, but since the summer Ive done it the other way round. I now always rinse first and then apply the foam afterwards as I believe it helps to remove more dirt before I get the buckets out.
I did a small poll in another forum. Here are few replies:
I'll post the other Forum Poll results when this has run its course
I tend to go straight onto the snowfoam. When I've rinsed the car first, the snowfoam tends to slide straight off. Seems to defeat the point!
Yes always pre rinse, get what you can off to start with.
Give the snow foam more chance to work, if car is treated correctly very little water should remain on the car after a rinse anyhow so shouldn't effect foam.
What do you do?Rinse first, snow foam will never remove heavily soiled motors on it's own I am afraid........![]()
