The drivers door check strap doesn't seem to be performing so well compared to the passenger side - the passenger side has very definite "notches" whereas the driver door could blow open in a slight breeze...
Can I gently file the notches in the drivers side to make it work better?
I would be amazed if the notches are not there all ready?, I would take a closer look at how the passenger side works, then compare to the drivers side, must be something different.....
2012 Civic 9G 2.2 i-DTEC SE
The drivers door is used more often than any other, so is likely to show more signs of wear and fatigue.
Yes - you can see the difference. The passenger side notches are well defined to they eye compared to the drivers side.
