So I've been struggling with this problem for quite a while now. 1 out of 5 times nothing happens when I want to open the doors with the key fob. It doesn't matter if it's good or bad weather, inside or outside, open woods or heavy industry. I noticed that the alarm LED doesn't light up anymore when this happens. I checked the battery and it measures something around 14 Volts - suppose that's OK. I can, however, open the door with the key itself, but I have to close it first, then open it.
The dealer already replaced the MICU and contacted Honda Tech Dept, but couldn't find anything. It's a rather small dealer, so I understand that they don't want to put in days of work and not get paid for it. However, I want this solved. I almost bought a Renault Megane, but decided to go with the Civic; didn't want the electrics to do funky stuff... go figure.
Any suggestions?
5-door, 1.4 vtec, MY10.
Cockup Specialist
I say 90% its your key. Have you changed the battery in the Key ?
:popcorn:
Yes, a very important bit I forgot to mention: The little red light on the key fob lights up when I click the open button, but the door still won't open. I have this issue with both my keys.
I have the same issue, although not as often as you describe. My dealer said it was most likely caused by interferring frequencies from other electric equipment. Had the battery changed, and the key reprogrammed. Didn't help. Can happen anywhere, no certain area worse than other. Guess you just have to live with it.
Just be happy you don't have a car with a "proper" keyless system / start button - when the car neither won't unlock or start because of interfering frequencies or electromagnetical fields due to cables in the air or in the ground, you will be happy that after all can put the key in the door and unlock your car in the old-fashioned way, turn on the ignition by hand, push the "wannabe" start button and drive away.
Not unheard of
I thought so too. But I don't know if they had their MICU replaced. I suppose I'll go with what morten said:
Just be happy you don't have a car with a "proper" keyless system / start button - when the car neither won't unlock or start because of interfering frequencies or electromagnetical fields due to cables in the air or in the ground.
Most of them certainly not.
I'm with you and Morten on the keyless thing too!
