Would someone be able to measure the width of their double din unit please?
The reason I ask is because I have just received the Connects2 fascia kit, but the rectangular surround is about 2 or 3mm too thin to allow my headunit to push through, the height is fine.
The surround measures 99mm x 174mm.
The headunit measures 99mm x 176.5mm.
Did you get your headunit to fit?
Looking at some pumpkin ones, but the size says it's 100mm x 178mm...
Pic link isn't working.
So I should be able to file a bit more off the surround? Also, I think I remember having to file something inside the dash for them to go all the way in, but can't find a pic of what it is that will need filing. Do you have one of those, as I imagine you've done it or it was your thread haha!
There are so many "how to's" in your mod thread!
Sent from my Nexus 6 using Tapatalk
Picture works fine. Depending on what browser you're using it may not like the space in the file name though.
Yeah, chrome on android throws a server error, but works if you go down to album level. Desktop works fine and I found the pic where you trimmed off the side. All good stuff to know before undertaking fitting!
