Hey guys.
I was wondering if you guys could give me some help!
Basically I bought and installed a Pioneer 2700bt (pretty sure that's what it's called) headunit and fitted it early last year Along with a connects 2.
Basically since fitting it (I've not had chance sort it) the DVD player doesn't work and my Radio signal is awful, occasionally I get signal then As soon as I drive off I lose it.
I know the Headunit has to be grounded to something around the handbrake to get it to work properly but does anyone know what bit it has to ground too? Or is there a way to bypass it and trick the Headunit into thinking that it is grounded/handbrake is up? As I can't adjust the brightness or anything on the screen atm and it's doing my nut it.
In regards to the radio signal have I just Plugged into the wrong wire or something on the connects 2? I put it on the Civinfo Facey B page a while back and a chap suggested swapping the wires around but I have lost the page
Sorry for the essay guys.
Thanks in advance!
Dave.
Thanks in advance!
Dave.
