So I've just ordered this
and also purchased the facia kit from hondabitz with universal wiring loom.
My only questions are
1. are these the only two bits I need? As I notice the facia doesn't come with a cage, will I need a cage?
2. any tips to make installation easier would be greatly appreciated.
Thanks!
Discussion Starter · #3 ·
the cage is inside with the double din generally, and all you need is a screwdriver and some patience
the double din has arrived and it seems to just have two sort of metal L shapes that attach to the side of the unit, is this the 'cage' ?
You'll need to attach those brackets to the stereo and the 'front' of the bracket attaches to the fascia. You'll see the screw holes on there. I think it was 3 on each side. Also you will need to remove the air vents from original fascia and put on the new one. Hope this helps.
Discussion Starter · #6 ·
excellent, thank you!
Discussion Starter · #7 ·
any ideas on how to mount the camera? e.g where? and how?
Any time mate
Unfortunately, I haven't done it yet myself. I don't have the time at the moment. But I have seen few guides on this forum on how to do it. Seems like a fairly simple job. You can use this guide. Its for sat nav models, but you can see how to do your wiring, etc.
