Hi
Once you have installed a double din aftermarket radio with a connects2 kit, do you have to remove the centre
consul again to remove it, or is a matter of just removing the 3 top screws and releasing it????
Should be able to get away with just taking out the top 3 screws, main reason for taking the entire centre console out is to get to the two holding it down at the bottom if I remember correctly.
Will need to take everything out if you wanna put the OEM unit back in though.
Also, depending how the head unit is fixed to the aftermarket fascia, you might not even need to undo those 3 screws at all. Might just be able to slide the head unit out of the cage, for example.
Hope this helps
yeah just remove the 3 top screws and it pulls fine, makes it a lot easier to change in the future :)
