Hi All.
The original Xenon lights on my 2006 Civic have both been smashed and can't be repaired. With the high cost to replace I decided the cheaper option would be to get halogen replacement headlamps. All other lights other that the main beams are working and I'm unsure of the issue. Does the downgrade require different wiring/lights?
Thanks.
You will need a conversation adapter to go from d2r to h7 & a few other things
If you are removing the Xenon, should that also mean that you are removing the ballast and the D2R connections?
Is there a multiplug or something on the headlight that is universal so the swap would be a cause of just unplugging one and plugging in the other?
