Hi all.
Sorry for not answering earlier - much work and organizing issues with kids.
Foreword: there are HDS and i-HDS software parts. As i understood the i-HDS part is for newer models, so for my Honda from 2011 i should use only HDS. Therefore all following part is about HDS only. Additional info - i am still struggling to get HDS working on Win11 laptop - there are issues with installing (i assume), because there are no shortcuts for HDS launcher on desktop after installation, and if i start it manually - then i get not that i am expecting to get (comparing to same laptop model with Win10). It is even not about drivers, but about software itself not running.
So to HDS + W10 part:
1. Install HDS on Win10 (i have used latest version i could get - 3.104).
2. then extract the folder "XHorse" from attached archive (rename it to XHorse.7z) into folder "c:\GenRad". This GenRad folder was created by HDS installer, and contains one subfolder "DiagSystem", so here comes 2nd folder XHorse. I had to pack this folder with password because Windows defender deleted this file 2 times i have tried to unpack it. So make sure to disable your antivirus software when unpacking it, and put this folder in its exception list. This was also described/warned in internet. The password is "XHorse".
3. open this folder and double click on file "c:\GenRad\XHorse\Xhorse64.reg". Make sure that the path is so a i wrote, or you can adjust the paths in this file if you want to have this folder anywhere else.
4. After it in cable select window you should get "XHorse HDS USB Cable" from manufacturer "China Aliexpress" (i just typed these strings in this REG file, so if you want - you can adjust it as you like). Select this item and go on with HDS software.
That's it.
If anyone will get troubles with this tutorial - let me know, and i will change it to more understandable sentences.
So, good luck!
