answers from creator of this csv file
no idea. in csv file there is only one entry for this. Probably you have changed something in that PID and later imported csv again.
I havent changed nothing.
then just delete one of those PIDs. As i said, it could be unintentionally that you have changed something. But csv file has only ONE definition for this PID. So the rest is made on your side.
EGT 1 is the temperature, that can be controlled to see the regeneration attempts: active regen normally pumps its value to range 540-640 °C, passive regen can heat it up to 460 °C.
Understood, so passive up to 460.C degrees and active from 540 to 640.
540-640 in working time. Please note that this temperature cannot change instantly, and raises/lgetting lower in some minutes.
read this thread (my post about this value
DPF follow-up with Honda HDS software ). It SHOULD go to 1 in active regen mode, but i cannon guarantee this as there is no description for any of 32 bits for this value, so i made formula for this PID from my experience/analyze only.
Yesterday I just turned on the car and it was showing 197 .. on the active regen, but surely the car wasn't doing a regen.
there are 2 PIDs - "active regeneration" and "automatic regeneration control status value". What of these 2 have you checked?
And i have to correct myself - "active regen" is zero when there is no active regen, and above zero - if regen is ongoing.
and again - read the link i have posted, and post the status value for the case if "active regen" is wrong in your case.
I checked the EGR "error" and EGR Comand, both of them were moving, if the car was actually doing a regen they shoudn't move right? but which one is the right one?
I don't know any dependence of EGR from active regen.
-Are the shown values okay for my car? 56.000 miles, remap for about 800 miles ..
I don't know what do you mean under "remap", and I don't really want to convert all values from imperial to metric to weight it. Sorry.
guys I can't connect my elm 327 to the stock headunit via bluetooth, I can connect it to my phone. but I wanted to use torque in the car..
Find a forum for your headunit, and ask there. There are too many variations of HUs with its own quirks concerning bluetooth. Some of them work only with special OBD adapters from same manufacturer, some need to set default pairing password to 1234, etc...
