1 - 9 of 9 Posts
Hi too All, can anybody tell me where the drainage run off hoses are behind the bulk head, as im getting water in the foot well when its raining, re sealed the windscreen, sealed up a tear in the inner wing, still coming in, it seems to be coming in heavier around where the petrol and bonnet latches, can anybody help, Many thanks Alshiv.
Have you checked the door seal on the body?
or the inner membrane under the door card and the drain holes for the driver's door?
could be getting in there and running forward if you park nose down a slope.
Thanks for your reply, ive checked the door drain holes, im wondering if its getting in by the plastic triangle trim by the wing mirror, had a look today cant see how you remove it, Any Ideas,
I think that just pops out, held in by plastic clips,
Fastener Location
: Clip, 1
A
  1. Pull the front pillar corner trim (A) back by hand to detach remaining lower clips, then remove the trim.
  1. Install the trim in the reverse order of removal, and note these items:
    • Check if the clips are damaged or stress-whitened, and if necessary, replace them with new ones.
    • Push the clip portions into place securely.
[TD]
no worries, took a while to find it.
fn2workshop.co.uk is the place to go but it only works using Internet Explorer
Removed these side trims today with some plastic trim removal tools i got off ebay, did the trick managed to not break any clips, ran a bit of silicon around the inside to see if that stops the leak, had a good look around, couldn't see any signs of how the waters getting into the foot well, still cant find the drainage hoses, might have to remove the wheel and plastoc arch internal cover and have a look.
Don't think there are any hoses as such
The water runs down from the screen past the bonnet hinges and out through the bottom of the wing by the door.
Seen a Video on YouTube, a guy resealing the windscreen water run off tray, behind there, theres some what looks like water run off holes right at the back, some of these looked blocked, ill take it apart tomorrow, and using an old wire coat hanger ill try and clear them, also looking to replace the perished rubber seal around the windscreen cowling as well
1 - 9 of 9 Posts
